Please help ukrainian man to programm mcu
vitasik88
Post by vitasik88 »
i'm from ukraine, bad know english. i need help. s.19 file i write in mcu with MON08 programmer and prog08sz program. I need write one file (mjljunior_vxxx) or 2 files (hc08sprg-kx8.abs and mjljunior_vxxx))? after programming one file mjljunior_vxxx, the soft MegaJolt Lite Jr Configurator see mcu, see changes if (MAP +vacuucm) see ignition map. But!!, when i change value, and click '''Commit Configuration to Flash' next window is Timeout reading runtime data. After i can not connect to MCU. I must MCU connect too MON08 programmer, erase module, again program module. Please help me if understand
Note, You will also need to write the bootloader for the application. You should review the motorola documentation on how this works. Good luck!
