CAN 2.0 interface I/O
sigtrm
Post by sigtrm »
Let's say I have some sensors which output CAN2.0A in Motorola format( I have full frame spec) how can I configure RCP mkII for use with custom sensors/CAN2 protocol.
Also how can I setup second CAN to output CAN 2.0 custom frames?
I suck at searching or I just can't find documentation for this, it would be nice if so one could point me to proper docs.
sigtrm
Post by sigtrm »
Ok, found some resources:
http://www.autosportlabs.net/RaceCaptur ... _Scripting
http://www.autosportlabs.net/RaceCaptur ... g_Examples
Should be enough, but is it it? or there is some more?
For integrating a new CAN system this is the essential guide:
http://autosportlabs.net/CAN_Bus_Integration
What kind of sensors are they?
sigtrm
Post by sigtrm »
brentp wrote:For integrating a new CAN system this is the essential guide:
That is what I wanted I think.
Brightwater
http://www.brightwater.co.uk/tms.html
I attached CAN spec from Brighwater. I will share code if/when I implement those;-)
*BTW, I was allowed to share it with RCP community.
Fantastic. Use the mapping framework seen in the integration guide to develop the mapping - post it here and we'll review.
Thanks for sharing!
-Brent
Ok, added to CAN database. thanks again! http://autosportlabs.net/CAN_Bus_databa ... chnologies
sigtrm
Post by sigtrm »
brentp wrote:Ok, added to CAN database. thanks again! http://autosportlabs.net/CAN_Bus_databa ... chnologies
Thank you brent, I am implementing this now, will post soon.
You switched Mul with Add in table on wiki;-) Multiplier can't be 0 obviously;-)
Have few additional questions:
1. After defining virtual channel I do not see it on the list Select Channel. I can see my channels only on last screen where all the values are listed.
2. Can you consider external editor for LUA? The one from scripting tab...($%$$&^. For example when I use
Code: Select all
print("DEBUG\n something")
it prints ok with newline, but after closing and reopening RCP code editor looks like this:
Code: Select all
print("DEBUG
 something")
3. Is debug window is on the same UI thread with Script Editor window? Because it is so slow when Poll is checked.
Thanks for catching the error. Fixed! http://autosportlabs.net/CAN_Bus_databa ... chnologies
we don't yet have an external editor - that simply looks like a bug to fix! You can print newlines with a println() also.
We do have some optimizing to do for the log window when there is a lot of data. You can also view the log via a terminal program, following these instructions: http://autosportlabs.net/CAN_Bus_logger ... al_Program
For the virtual channel update, we are fixing that in the 2.8.0 / 1.3.0 release of the firmware, coming likely within a week.
-Brent
sigtrm
Post by sigtrm »
brentp wrote:Thanks for catching the error. Fixed! http://autosportlabs.net/CAN_Bus_databa ... chnologies
-Brent
3 more questions:-)
1. Why 10 vchans limit? 4 wheels x temp+pressure and I have only two left:-(
2. Can I update wiki myself or do I have to post here or send to some email?
3. How much Lua is supported? Which libs ?
Here you go:
1) Actually, in the latest firmware you can set up to 30 virtual channels - just fixed the Lua documentation.
2) We have registrations constrained due to spam. Please email us at [email protected] to be a wiki contributor. Thank you!
3) Only the basic Lua libraries are supported and some math functions. We're looking to add the bitop() functions as well in a future firmware release. If there was a specific function you were looking for, let us know!
sigtrm
Post by sigtrm »
brentp wrote:Here you go:
I updated wiki a little for Brightwater TPMS, I will fix and clean it ASAP:
http://www.autosportlabs.net/Brightwater_TPMS_CAN
http://www.autosportlabs.net/CAN_Bus_da ... _.28WIP.29
Thank you for updating the information!
UMS Tuning
AEM CAN
Post by UMS Tuning »
If it helps, here are all of the AEM addresses, im planing to use my RCP with my AEM Infinity.
http://aemelectronics.com/sites/default ... Public.pdf
Tony
