How to get all channel names in drop downs?
Not sure if it's my computer or what, how do you get to the entire list of channel names in the new RaceCapture app? There isn't a scroll bar on the side and the up/down arrows don't move the selection up and down the list. Consequently I can't get to the spot to select the desired channel names because they get cut off like this:
- Channel_Name.jpg (30.04 KiB) Viewed 1144 times
- Configuration_Menu.jpg (30.37 KiB) Viewed 1144 times
Interesting, I just discovered that the menus can be scrolled through on a touch screen just like is customary on a smartphone. Just flick and scroll.
I discovered this because I got an HP Stream 7 tablet computer which runs Windows 8.1. Purely by accident that I just discovered the touch screen menu flick.
So how do you scroll through the channel name list when using a normal computer?
It shouldn't be assumed that everyone has a laptop with scrolling from the trackpad. I'm using a Sony Vaio running Windows 7, which is quite an adequate machine for this purpose and isn't that ancient. It doesn't have a mousepad which supports scrolling, not that I can tell.gizmodo wrote:You have to use the mousewheel. If you're on a laptop you'll need to enable scrolling from the trackpad.
How about a simple up down on the cursor as a backup for those of us who don't have a trackpad with scrolling or don't want to use a mouse in the car.
