Right and Left Air Fuel ratio
rocket6706
Post by rocket6706 »
I would like some advice on using the "Customize Channel" feature in the Windows App by identify AFR by right (AFRR) and left (AFRL) channels, and ensure the dashboard will also respond accordingly. I can change the name in the Sensor customization, but then the RCP does not recognize the name on the dashboard because I only have AFR as a single drop down. How do I connect the two.
Using a Wego IIID controller from Daytona Sensors with qty (2) wide band O2 sensors in my application. I have "mapped" analog 1 and Analog 2 as AFR converting respective 0-5 v to AFR output. I can place the gauges on right and left side of screen to visually correspond, just can't make all the mnemonics align.
Rocket 6706
Hi Rocket,
Are you using the current production android app or the Beta app?
If you're using the new beta app it will show up in the list of available channels, just as in the desktop app. To sign up for the beta app follow the instructions here:
http://www.autosportlabs.com/racecaptur ... e-tablets/
-Brent
