Author |
Message |
dimondjack
 Track Map Not Recognized
I raced at Lime Rock last weekend and the auto track map seemed to work intermittently. It didn't work for the first two stints (though the GPS dot was in the right spot) , and then worked on the third stint, and then didn't work again on the 4th stint. The unit gets reset every time we have to cycle power to start, but it acquired GPS quickly.
When the track wasn't recognized lap times and predictive lap timing didn't work. I set the track to manual mode for the second day and the system worked flawlessly.
So, what causes the system to know what track it is at for one stint and not the rest? I'd like to use the pre-programmed track maps if possible, but I can't risk the lap times not working. Is there a trick to make sure they are reliable?
Thu Aug 27, 2015 11:09 pm |
adam
I have this problem as well. Am not finding the lap timer to be as reliable as I would have liked.
Fri Aug 28, 2015 5:40 pm |
rdoherty
Hi guys, sorry to hear the track detection didn't work. We have a small fix in our next firmware release that should help RCP detect the track it is at.
_________________ Ryan Doherty
Autosports Labs
Thu Sep 10, 2015 7:37 pm |
dimondjack, what firmware version were you on when you experienced this problem?
There is a pre-programmed radius for detecting the current track and from feedback, the radius might be too tight at 1KM, We're expanding that to 5KM.
Also, in case you're not aware, the app's status page shows the track detection status.
The 2.8.5 release will contain this update; keep an eye on the software page for that release. Thanks for your patience!
-Brent
_________________ Brent Picasso
Thu Sep 10, 2015 11:42 pm |
dimondjack
I had downloaded the newest firmware right before going to the race. I believe it was 2.8.3 for Mk1.
Tue Sep 15, 2015 1:00 am |
Give it a shot with the latest firmware and let us know. the 2.8.5 firmware which is coming out shortly should help; it expands the detection radius from 1 to 5km, in case you were pitted really far away from the target.
Tue Sep 22, 2015 6:56 pm |
Also, our latest app (1.3.13) available in google play store will show the track detection status in the top. We know how important lap timing is, so we dedicated a spot in the toolbar for this information.
Mon Oct 19, 2015 6:18 pm |
dimondjack
Good to know. Unfortunately I won't be able to test it until I'm at a track again next year!
Mon Oct 19, 2015 6:28 pm |
If you're curious, you can also do some basic tests around the block in your street car and manually set a start/finish point. That will let you do some test laps.
Let us know if we can help with anything else. Thanks!
Mon Oct 19, 2015 7:52 pm |
