Megajolt with Cherry GS100502 hall effect sensor
twincamspit
Post by twincamspit »
I've spent ages trying to find the answer to this - can someone let me know whether I can use a hall-effect sensor such as the Cherry GS100502 with the Megajolt in place of the Ford VR sensor?
Everything I find when searching for hall effect sensors relates to the RaceCapture Pro rather than MJ/E
I appreciate that generally VR sensors are tougher than Hall effect, but the mount on my engine is for an M12x1 threaded VR sensor, and VR sensors with this thread are simply unavailable in the UK whereas M12x1 hall-effect sensors such as the GS100502 are easy to find.
Thanks in advance,
Richard
Spitfire MKIV with Fiat 132 DOHC engine/box, not much room for a trigger wheel!
http://s192.photobucket.com/albums/z225 ... fitted.jpg
