Can some one post on testing the power supply what pins do you have 5 volts across ect, according to the schematic p8 and p9 are ground and p7 and p6 are +12 can you use a 9 volt battery to test thie power supply and direction would be appriciated
thank you in advance
testing power supply
Luca Lagonigro
I've used a wallwart adapter
I've used a wallwart adapter set on 9V most of the time , I think the 9V battery will do just fine.
