0x350 - 50hz - logger 1
0x359 - 50hz - logger 1
0x340 - 200hz - ECU 1
When I remove the 0x340 filter, the 0x350 and 0x359 ID transmit and log very nicely. When I add in the 0x340 ID, the 0x340 data looks great, but the other 2 slow down, and randomly get seen at around 1 sample every 5 seconds.
Any thoughts on what is going on here?
I tried 1000hz tickrate as well. Was a little better for the slower ID's, but not right.
Code:
setTickRate(100)Id1 = addChannel("throttle1",100,1)
Id2 = addChannel("throttle2", 100,1)
Id3 = addChannel("rpm",100,1)
Id4 = addChannel("press1",100,1)
Id5 = addChannel("counter1",100,1)
Id6 = addChannel("counter2",100,1)
Id7 = addChannel("press2",100,1)
Id8 = addChannel("press3",100,1)
Id9 = addChannel("angle1",100,1)
setCANfilter(1,0,0,0x301,0x1FF)
setCANfilter(0,0,0,0x359,0x1FF)
setCANfilter(0,1,0,0x350,0x1FF)
setCANfilter(0,2,0,0x340,0x1FF)
function onTick()
id, ext, data = rxCAN(1,100)
if id==0x301 then
throttle1=(data[1]*256+data[2])/10
setChannel(Id1,throttle1)
throttle2=(data[3]*256+data[4])/10
setChannel(Id2,throttle2)
rpm_can=(data[5]*256+data[6])*6
setChannel(Id3,rpm_can)
press1=(data[7]*256+data[8])
setChannel(Id4,press1)
end
id, ext, data = rxCAN(0, 100)
if id==0x350 then
counter1=data[1]
setChannel(Id5,counter1)
counter2=data[2]
setChannel(Id6,counter2)
end
if id==0x359 then
press2=data[1]*256+data[2]
setChannel(Id7,press2)
press3=data[3]*256+data[4]
setChannel(Id8,press3)
end
if id==0x340 then
angle1=(data[7]*256+data[8])/10
setChannel(Id9,angle)
end
local tmp1 = getChannel(7)--low boost counter
local tmp2 = getChannel(8)--hi boost counter
local tmp3 = math.floor((getChannel(9)*100)/256/100)--boost L
local tmp4 = math.floor((getChannel(9)*100-tmp3*100*256)/100+.5)
local tmp5 = math.floor((getChannel(10)*100)/256/100)--boost R
local tmp6 = math.floor((getChannel(10)*100-tmp5*100*256)/100+.5)
local tmp7,tmp8 = math.floor((getChannel(11)*100)/256/10)--ign
local tmp8 = math.floor((getChannel(11)*100-tmp7*10*256)/10+.5)
local msg = {tmp1,tmp2,tmp3,tmp4,tmp5,tmp6,tmp7,tmp8}
txCAN(1, 0x302, 0, msg)
end
