Code: Select all
--Configure virtual channels
SpeedGPS = addChannel("SpeedGPS", 10, 2, 0, 200, "kmh")
--Pin assignments for shift light--
--RPM is pin 20 / PulseIn 1
--set the jumpers to ON
--First light is pin 6 / Vout1 10Hz 100 100 0.1 / #2 on shift light - green
--Second light is pin 5 / Vout2 10Hz 100 100 0.1 / #1 on shift light - yellow
--Third light is pin 4 / Vout3 10Hz 100 100 0.1 / #3 on shift light - red
-- CONSTANTS --
FREQ_HZ = 25 --1000*1/FREQ_HZ=loop time in ms. e.g. 25Hz=40ms--
loop_time = 1000 * 1 / FREQ_HZ
MAX_BLINK_PERIOD = 1000 --in ms (1s or 1000ms is reasonable value)--
MAX_ON_TIME = 500 --in ms (0.5s or 500ms, half off/on is reasonable value--
testRPM = 2200 --test interface for use on bench--
LL1 = 5500 --light 1 lower threshold to start blinking--
UL1 = 6000 --light 1 upper threshold above which goes solid--
LL2 = 6000 --light 2 lower threshold to start blinking--
UL2 = 6500 --light 2 upper threshold above which goes solid--
LL3 = 6500 --light 3 lower threshold to start blinking--
UL3 = 7000 --light 3 upper threshold above which goes solid--
-- FUNCTIONS --
function ctON(ul,ll)
RPM=getTimerRpm(0)
--RPM=testRPM
factor = 0.5 * FREQ_HZ * (1 - (ul - RPM) / (ul - ll))
if factor >= 0.5 * FREQ_HZ then --can't blink faster than tickRate/2--
on_time = MAX_ON_TIME
elseif factor < 1 then --can't blink slower than max period--
on_time = 0
else
on_time = MAX_ON_TIME / factor
end
return on_time / loop_time
end
function ctMAX(ul,ll)
RPM=getTimerRpm(0)
--RPM=testRPM
blink_period = MAX_BLINK_PERIOD / factor
return blink_period / loop_time
end
-- Ini --
setTickRate(FREQ_HZ)
j = 0
k = 0
l = 0
-- RUN --
function onTick()
setChannel(SpeedGPS, getGpsSpeed() * 1.61)
--start light 1 section--
if j < ctON(UL1,LL1) then
setAnalogOut(0,0)
else
setAnalogOut(0,10) --with value of 5 measured 2.2V and dim light so set to 10, measured 4.75V
end
if j < ctMAX(UL1,LL1) then
j = j + 1
else
j = 0
end
--end light 1 section--
--start light 2 section--
if k < ctON(UL2,LL2) then
setAnalogOut(1,0)
else
setAnalogOut(1,10) --with value of 5 measured 2.2V and dim light so set to 10, measured 4.75V
end
if k < ctMAX(UL2,LL2) then
k = k + 1
else
k = 0
end
--end light 2 section--
--start light 3 section--
if l < ctON(UL3,LL3) then
setAnalogOut(2,0)
else
setAnalogOut(2,10) --with value of 5 measured 2.2V and dim light so set to 10, measured 4.75V
end
if l < ctMAX(UL3,LL3) then
l = l + 1
else
l = 0
end
--end light 3 section--
endThen with those two lines activated, the log shows the following:lua: Stopping...
lua: Initializing...
lua: Loading lua script (len = 2685): SUCCESS!
lua: memory usage: 11KB
Info log
Debug loglua: Stopping...
lua: Loading lua script (len = 2681): [lua] Memory ceiling hit: 17545 > 16384
ERROR!
lua: startup script error: (not enough memory)
timebase/logging/telemetry sample rate: 50/25/25
How can adding two lines make such a difference in memory usage? Really out of memory, or an overflow caused by incorrect script code on those two lines?RAM Freed: 22
[lua] RAM Freed: 27
[lua] RAM Freed: 19
[lua] RAM Freed: 28
[lua] RAM Freed: 22
[lua] RAM Freed: 23
[lua] RAM Freed: 22
[lua] RAM Freed: 24
[lua] RAM Freed: 29
[lua] RAM Freed: 28
[lua] RAM Freed: 25
[lua] RAM Freed: 25
[lua] RAM Freed: 22
[lua] RAM Freed: 21
[lua] RAM Freed: 23
[lua] RAM Freed: 23
[lua] RAM Freed: 21
[lua] RAM Freed: 34
[lua] RAM Freed: 28
[lua] RAM Freed: 20
[lua] RAM Freed: 26
[lua] RAM Freed: 26
[lua] RAM Freed: 29
[lua] RAM Freed: 25
[lua] RAM Freed: 20
[lua] RAM Freed: 20
[lua] RAM Freed: 22
[lua] RAM Freed: 23
[lua] RAM Freed: 20
[lua] RAM Freed: 25
[lua] RAM Freed: 20
[lua] RAM Freed: 22
[lua] RAM Freed: 26
[lua] RAM Freed: 19
[lua] RAM Freed: 1024
[lua] RAM Freed: 0
[lua] RAM Freed: 192
[lua] RAM Freed: 360
[lua] RAM Freed: 340
Sample buffers allocated: 5
Why does Lua script length decrease when those two lines are activated? That sounds strange.....
P.S. yes, I'm running the latest Mk1 firmware 2.8.7
