RPM signal
palad
RPM signal
Post by palad »
Hello
I'm wondering how can I get a one cilindre two stroke kart rpm signsl to read it in racecapture.
Anyone help me please ?
If the ignition module / coil is similar to a conventional coil on an automobile, then you might be able to use the CoilX module, here:
https://wiki.autosportlabs.com/CoilX
See the full information on this page. Otherwise, you'll need to generate a relatively clean RPM signal from your RPM trigger.
Hope this helps, let us know what you find out.
