It lives! now a question....
Josh_b
Post by Josh_b »
i assembled my mjlj and it talked to my pc, great stuff, now a question about my trigger wheel, its the same outer diameter as my pulley, will i need a spacer between the pulley and wheel so the the metal from the pulley wont interfere with integrity of the signal see pic: http://www.bowler.fslife.co.uk/sensorwheel.jpg
Josh_b
will this trigger wheel arrangement be ok?
Post by Josh_b »
my trigger wheel is the same outer diameter as my pulley, will i need a spacer between the pulley and wheel so the the metal from the pulley wont interfere with integrity of the signal see pic: http://www.bowler.fslife.co.uk/sensorwheel.jpg
sorry to repeat msg i dont think my first one had a good title
You should be fine with your
You should be fine with your setup. A friend of mine welded the sensor wheel right to a steel pulley- see his setup under the ignition section on http://www.4agte.com
