heres my jobby
Josh_b
heres my jobby
Post by Josh_b »
toplessvw
looks good
Post by toplessvw »
looks good what project box do you have it in? and just a question on the map sensor, is it a different map sensor than the digikey one because it looks like it is upside down looks good
Josh_b
I dont think its upside down
Post by Josh_b »
you cant tell from the pic but i installed it with the writing showing, as in Brents. Its the same as Brents too, from Digikey. the box is just one i got Maplins (uk) i couldnt find a nice one like Brents so i got a cheapo one L?22 is the code i think £2
The sensor does mount with th
The sensor does mount with the vent pointing down! this is important. So Josh, you do have it correct.
Another way to verify is that the sensor's pin #1 (the pin with the notch) is aligned with the pad that has the 'dot' next to it.
It seems that the mounting holes are a little off for the sensor. you should re-drill them to be in alignment, and then bolt the sensor down to the board.
Hey, your board looks great, by the way! :)
