Podium Live Brake Switch Input
anastos
Post by anastos »
Hi All,
Running RCP Mk3 with basic On/Off brake switch input on GPIO 1.
The data on the dashboard in Race Capture is working fine - reports "1" when brake applied "0" when not.
When I view the brake input on Podium Live it is represented as brake pressure 0 - 2000 and the reading does not change when brake applied. How can I get this corrected?
Dave
Anastos
Hi Dave,
When the channel is called 'Brake' it's expecting a linear brake pressure sensor. Try changing the channel name to BrakeSW and see if that turns it into a digital gauge instead where you can see the 0/1.
anastos
Post by anastos »
That worked :)
Thank You
Dave W.
Anastos
