MK2 with bluetooth and wifi
MrBlahh
Post by MrBlahh »
is there any way to use a mk2 with bluetooth and wifi? I Was not sure if they both use the same port on the mk2, preventing me from using both.
I need to use bluetooth for HLT but I would like to start using another device as a dashboard & podium too
dewittpayne
Post by dewittpayne »
No, you don't. Wi-Fi also works with HLT. The RaceCapture/Track only has Wi-Fi.
Yes indeed; for MK2 you can connect both BT and WiFi. BT plugs into the inner port (closer to the button), and WiFi plugs into the outer port.
For reference, MK3 and RaceCapture/Apex both have BT and WiFi on-board.
MrBlahh
Post by MrBlahh »
I do have to use bluetooth for HLT or it cannot control the gopro over wifi.
that said the gopro's are buggy and fail to record as often as they record.
dewittpayne
My Hero3 has been quite reliable as long as the battery is charged. The later versions seem to have 'features' that make them less reliable or even incompatible.
MrBlahh
Post by MrBlahh »
I have a 3 and I never had trouble with it either
I'm hoping some of the competition gets support too like the yi cam
