Installation advisory for hot enviroments
We've had some reports of the RaceCapture/Track's plastic enclosure softening / deforming on hot days (> 90F degrees) when mounted on the dash.
Even though the ABS enclosure is rated to over 100C, we theorize there are some cases where the windshield is focusing the sun's rays and intensifying the effect.
If you're running RaceCapture/Track like this in a hot environment, we recommend putting the unit away when not racing. If you've experienced a case where the enclosure has been heat-deformed, please email [email protected] and we'll promptly get it repaired it for you.
