Now i am looking for a ignition map, at first it started after a lot of starting and revd verry hard, found that there was a vacuum leak. Fixxed it and did not run since then
Now even with megajolt disconnected, it will not even start up, a bitt of backfire, not running annymore.
I have tried the standard map on the cd rom, and with vacuum advance disconnected, no luck.
Should i take vacuum advance from the suction off the blower ore use the pressure side ?
I have sett the megajolt to pressure and with the needle saying 100 kpa this is atmopsheric pressure ? So iff the needle go's tot lets say 30 this is more vacuum ?
