Speed not displaying
torkey
Post by torkey »
I am running the MK2 and recently upgraded my LG tablet to version 1.10.2.
After the upgrade my speed gauge stopped working. The speed gauge is on the dashboard but there are no numbers in the speed gauge when stopped or when moving. Any ideas what I might have done to cause this to happen and what I can do to fix it?
Hi - here are a few of things to check:
* Check that you have a GPS lock - you won't get speed if GPS has not acquired a satellite lock. GPS lock is indicated in the upper right of the app; green means 'lock'
* Check that you don't have any other channels defined as 'Speed' (such as an OBDII channel) since they will interfere with each other
* Check the raw channels dashboard view to confirm updating of all values
