Flashing read me recommends saving and then reinstalling configuration.
This wipes the added CAN bus configuration fields.
Can I reflash to 2.11.0 again to get the new settings back?
Is there a way to avoid building the configuration from scratch again? The unit is not installed in the default orientation and has analog sensors so kind of a PITA.
Old Config file loaded onto firmware v.211.0
wrandleman
What that alert means - before flashing new firmware, make sure you have the configuration saved to a file. Do this by reading the current configuration from the unit, then press 'Save' to save it to a file.
After flashing, you can restore your configuration from that saved file - every setting should be restored.
Let us know how it works out!
wrandleman
