Reply to topic Page 1 of 1
Connecting to Miata Fuel Sensor
Post Connecting to Miata Fuel Sensor
Hi, so AnalogX reads as as 0-5V signal, I am not a radioshack, build a component type guy.. I like to buy things Smile
Anyone know of something I can put inline to map Miata Fuel tank Level back ?
Here's the Miata Fuel Sensor specs and research from a few forums..
Gauge 110 ohm adjustable fuel converter
Looks like 12V
Gauge is 110-0 ohm fuel sender (Mazda Miata)
Engine Running vs. Not can change Ohm's (there's a calibration), you can check on your voltmeter.
Full: 3 ohms
3/4: 15.8 ohms
1/2: 32.5 ohms
1/4: 64.2 ohms
E: 110 ohms
notes:
i believe the fuel sender is a variable resistor, so the signal to the gauge in the cluster is a resistance value, something in the neighborhood of 0 to 90 or 100 ohms. I think there is a tap out on the back of the cluster where you can read the voltage from the gauge, but if you remove the cluster you wont have it.
Post
The original cluster has a pull-up resistor, which translates the fuel gauge reading into a voltage divider network.
https://learn.sparkfun.com/tutorials/voltage-dividers
You can enable the built-in 2.2K pullup resistor for shiftX2 by bridging the solder pad, or you can add a pull-up resistor externally. The 2.2K resistor is mostly designed to work with high resistance temperature sensors - the more common application. So, an external 220 ohm pullup resistor might work better for you.
There's also a handy voltage divider calculator here that will show you the output voltage based on the varying resistances:
http://www.ohmslawcalculator.com/voltage-divider-calculator
Hope this helps Smile
_________________
Founder, Autosport Labs
