Reply to topic Page 1 of 1
Data Rate Question
Post Data Rate Question
I am considering an APEX unit for a little bit higher speed vehicle.
Do I understand correctly that the maximum rate at which the APEX unit will communicate data samples to the podium display software is 10 samples per second when communicating via the cellular network and 50 samples per second when communicating via wifi. Surely that is per data channel and NOT per apex unit. If the APEX unit has 100 channels of CAN data and each channel is being read and transmitted at 10 conversions per second then that is about 1Kz of data throughput which sounds a little more realistic. Which is it?
View user's profile Send private message AIM Address
Post
Cellular telemetry is limited (downsampled) to 10Hz per channel, and local telemetry is constrained to 50Hz, correct.
_________________
