RaceCapture dies during startup on Huawei P10 Lite
lightningrod
I've installed the version from the Android Play Store. I get the initial splash screen but the app dies after a few seconds.
I have it running OK on my (very) old Samsung Galaxy for now.
Please let me know if there is anything I can do to help debug this.
Rod.
Rod.
lightningrod
If you don't see any popup errors, you may be able to fetch a crash log using a utility.
See:
https://stackoverflow.com/questions/244 ... roid-phone
and, linked from the above article:
https://play.google.com/store/apps/deta ... tb.alogcat
https://play.google.com/store/apps/deta ... byTW&hl=sk
If you get anything useful in the crash log, please post it here. Thanks!
See:
lightningrod
I captured about 9000 lines of logs in 5 seconds, so there's more data available than just this, but here are the logs from immediately before and after the crash. Let me know if there is something more specific I can look for.
Code: Select all
10-12 09:05:42.475 17676 17696 I ServiceManager: Waiting for service SurfaceFlinger...
10-12 09:05:42.483 1384 1407 I art : Explicit concurrent mark sweep GC freed 33781(2MB) AllocSpace objects, 13(996KB) LOS objects, 6% free, 57MB/61MB, paused 3.341ms total 244.250ms
10-12 09:05:42.877 10388 10428 W linker : /data/data/com.autosportlabs.racecapture/files/app/lib/python2.7/lib-dynload/_sqlite3.so: is missing DT_SONAME will use basename as a replacement: "_sqlite3.so"
10-12 09:05:42.955 10388 10428 W linker : /data/data/com.autosportlabs.racecapture/files/app/lib/python2.7/site-packages/sqlalchemy/cprocessors.so: is missing DT_SONAME will use basename as a replacement: "cprocessors.so"
10-12 09:05:43.078 10388 10428 W linker : /data/data/com.autosportlabs.racecapture/files/app/lib/python2.7/site-packages/sqlalchemy/cutils.so: is missing DT_SONAME will use basename as a replacement: "cutils.so"
10-12 09:05:43.083 10388 10428 W linker : /data/data/com.autosportlabs.racecapture/files/app/lib/python2.7/site-packages/sqlalchemy/cresultproxy.so: is missing DT_SONAME will use basename as a replacement: "cresultproxy.so"
10-12 09:05:43.377 1384 1384 I TrafficMonitor: update:rxPkts:2,txPkts:1,rxBytes:136,txBytes:64
10-12 09:05:43.377 1384 1384 I TrafficMonitor: start expired. level:-1
10-12 09:05:43.377 1384 1384 I TrafficMonitor: gettimer:interval=2000
10-12 09:05:43.456 471 471 E ServiceManager: try to find service failed, not allowed access from isolated processes.
10-12 09:05:43.456 26287 26308 I ServiceManager: Waiting for service SurfaceFlinger...
10-12 09:05:43.476 471 471 E ServiceManager: try to find service failed, not allowed access from isolated processes.
10-12 09:05:43.476 17676 17696 I ServiceManager: Waiting for service SurfaceFlinger...
10-12 09:05:43.500 10388 10428 I python : [ERROR ] [Main ] crash caught: Reference is 5eb9700e378b4164b7800bbe846f6be8
10-12 09:05:43.501 10388 10428 I python : [CRITICAL] [Traceback (most recent call last)]
10-12 09:05:43.501 10388 10428 I python : File "/home/brent/git-projects/RaceCapture_App/.buildozer/android/app/main.py", line 608, in <module>
10-12 09:05:43.501 10388 10428 I python : File "/home/brent/git-projects/RaceCapture_App/.buildozer/android/app/main.py", line 168, in __init__
10-12 09:05:43.501 10388 10428 I python : File "/home/brent/git-projects/RaceCapture_App/.buildozer/android/platform/build/dists/racecapture/private/lib/python2.7/site-packages/kivy/app.py", line 780, in user_data_dir
10-12 09:05:43.501 10388 10428 I python : OSError: [Errno 2] No such file or directory: '/sdcard/racecapture'
10-12 09:05:43.538 1384 1523 E WifiConfigManager: updateConfiguration freq=2452 BSSID=f4:f2:6d:b4:35:80 RSSI=-38 "RADNet"WPA_PSK
10-12 09:05:43.601 10388 10428 I python : Sentry is attempting to send 1 pending error messages
10-12 09:05:43.601 10388 10428 I python : Waiting up to 10 seconds
10-12 09:05:43.601 10388 10428 I python : Press Ctrl-C to quit
10-12 09:05:44.236 10388 10428 I python : Python for android ended.
--------- beginning of crash
10-12 09:05:44.246 10388 10388 F libc : Fatal signal 11 (SIGSEGV), code 1, fault addr 0x4 in tid 10388 (abs.racecapture)
10-12 09:05:44.247 383 383 W : debuggerd: handling request: pid=10388 uid=10141 gid=10141 tid=10388
10-12 09:05:44.360 489 489 E Thermal-daemon: [pa_0] temp_new :31 temp_old :30
10-12 09:05:44.362 1844 2246 I ThermalService: Receive temperature change, type: 1, temp: 31 from thermald
10-12 09:05:44.362 1844 2408 W HwThermalStateManager: warning: no config thermal type:1 temperature:31
10-12 09:05:44.362 1844 2408 I LowBatteryManager: Only handle msg event!
10-12 09:05:44.362 489 489 E Thermal-daemon: Report temperature: [pa_0] temp :31 report_threshold:1
10-12 09:05:44.364 489 489 E Thermal-daemon: [ap] temp_new :34 temp_old :35
10-12 09:05:44.364 1844 2481 I ThermalService: Receive temperature change, type: 0, temp: 34 from thermald
10-12 09:05:44.365 489 489 E Thermal-daemon: Report temperature: [ap] temp :34 report_threshold:1
10-12 09:05:44.365 1844 2408 I LowBatteryManager: Only handle msg event!
10-12 09:05:44.441 10439 10439 F DEBUG : *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
10-12 09:05:44.442 10439 10439 F DEBUG : Build fingerprint: 'HUAWEI/WAS-LX3/HWWAS-H:7.0/HUAWEIWAS-LX3/C605B120:user/release-keys'
10-12 09:05:44.442 10439 10439 F DEBUG : Revision: '0'
10-12 09:05:44.442 10439 10439 F DEBUG : ABI: 'arm'
10-12 09:05:44.442 10439 10439 F DEBUG : pid: 10388, tid: 10388, name: abs.racecapture >>> com.autosportlabs.racecapture <<<
10-12 09:05:44.442 10439 10439 F DEBUG : signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 0x4
10-12 09:05:44.442 10439 10439 F DEBUG : r0 00000001 r1 00000001 r2 00000000 r3 00000001
10-12 09:05:44.442 10439 10439 F DEBUG : r4 e54f7780 r5 00000000 r6 00000000 r7 d60c17d0
10-12 09:05:44.442 10439 10439 F DEBUG : r8 f365b008 r9 f2484f00 sl f2484f8c fp ffb48dc4
10-12 09:05:44.442 10439 10439 F DEBUG : ip d607ec24 sp ffb48c00 lr d5fc63e9 pc d5fbc0aa cpsr 800f0030
10-12 09:05:44.444 10439 10439 F DEBUG :
10-12 09:05:44.444 10439 10439 F DEBUG : backtrace:
10-12 09:05:44.452 10439 10439 F DEBUG : #00 pc 000c00aa /data/app/com.autosportlabs.racecapture-1/lib/arm/libpython2.7.so (PyThreadState_New+93)
10-12 09:05:44.452 10439 10439 F DEBUG : #01 pc 000ca3e5 /data/app/com.autosportlabs.racecapture-1/lib/arm/libpython2.7.so (PyThread_acquire_lock+76)
lightningrod
lightningrod
lightningrod
lightningrod
lightningrod
