Some CAN bus values cannot be configured from the RaceCapture App on Windows (I'm using Windows 10, I don't know about other versions). In particular, CAN bus data offsets higher than 5 cannot be programmed because the select boxes drop below the dialog and do not show and the Units Conversion cannot be selected because there is no way to move right one more slot on the CAN Bus Channel Mapping dialog.
I've attached screen shots to help clarify the issues.
Doug
Cannot Completely Configure CAN bus via CAN Channel Mapping
- The offset drop down will not go past 5. Since Analog input 1 on the AnalogX is offset 6, you cannot use that analog input of the AnalogX.
- OffsetLimit.jpg (122.79 KiB) Viewed 3283 times
- The online documentation shows a Units Conversion dialog to the right of the formula dialog. However, there is no way to navigate to that dialog - at least none of the obvious things will take you there.
- NoUnits.jpg (26.82 KiB) Viewed 3283 times
