Uk source for vacuum pipe bulkhead connector and vauum hose?
goldminijohn
Post by goldminijohn »
Hi there,
Does anybody know of a uk source for the brass bulkhead hose connectors and vacuum pipe needed if using the map option?
Cheers,
John
MartinM
Pipe is easy - any autopart
Post by MartinM »
Pipe is easy - any autopart store, about 40p/metre
Not sure about the connector. You have three choices, obvious pros and cons between each one:
- don't use one - take the pipe straight to the sensor. Need some strain relief at the sensor though
- make one - or get a mate with a lathe to make one in a few minutes - just cut the head off a M8 bolt, turn down at each end to slightly bigger than the inside diameter of the pipe and drill through the middle
- keep looking(!)
