Issue #1:
I created a can mapping for MAP.
* I can't change the units, precision, or any settings with the customize gear. If I change the units, hit check, hit check again, and then edit the channel, the change is immediately gone.
Issue #2:
If I create a CAN mapping and immediately customize it to have a name of Manifold, with various settings, I cannot insert this on the dashboard.
(1.9.0) Various CAN mapping issues
This does not reproduce for us. Hi Erik, does the channel editing issue reproduce with the latest version? you can install different versions side by side on windows, FYI. Does it happen on Android?
The channel won't be available in the list of available channels in dashboard until the config is written to the RaceCapture device.
I'm trying to program offline. No unit is connected. I'm getting everything set up so I can go to the shop next week and dump the program into the unit.
I'd like to be able to set and configure everything without being connected.
I'll install the latest and give that a try. The CAN mapping section didn't have the same crashing issue.
100% reproducible in 1.11:
* Open 1.11 program - NO LOGGER CONNECTED
* Open attached file (rename because .rcp attachments not allowed)
* Go to setup
* Go to CAN mapping
* Click +
* Click Channel
* Select MAP from dropdown
* Set rate to 50Hz (probably not relevant)
* Click Gear next to MAP channel
* Change Units to PSI
* Click Check
* Click Check
* Click edit for mapped MAP channel
* Click gear
Actual behavior:
* Shows KPa (default)
Expected behavior:
* Shows PSI (changed setting)
* Go to setup
* Go to CAN mapping
* Click +
* Click Channel
* Click Check
* Click Check
* Click gear
Actual behavior:
Expected behavior:
- reproducer-canmap.zip
- Reproducer RCP file
- (2.07 KiB) Downloaded 404 times
