ShiftX with /Track
Q&A For ShiftX2, RGB sequential shift light <a href="https://wiki.autosportlabs.com/ShiftX2">Installation and Operation Guide</a>
EcotecMiata
ShiftX with /Track
Post by EcotecMiata »
I'm assuming this won't work with race capture/track due to lack of LUA?
Paul
EcotecMiata
Anyone?
Sorry, it will not work with RaceCapture/Track.
turbogrill
Post by turbogrill »
brentp wrote:Hi,
Why wouldn't it work?
RaceCapture/Track MK1 does not support Lua scripting, which is currently needed to control ShiftX2. The new RaceCapture/Track MK2 currently on pre-order does support Lua scripting, and can work with ShiftX2.
Thanks - Hope that clarifies things!
petik
Post by petik »
brentp wrote:RaceCapture/Track MK1 does not support Lua scripting, which is currently needed to control ShiftX2. The new RaceCapture/Track MK2 currently on pre-order does support Lua scripting, and can work with ShiftX2.
Brent, will it also work when using the Legacy adapter on one of the buses? Not sure how the mk2 connection ports are setup.
RaceCapture/Track MK2 with it's dual CAN bus can work with ShiftX2 using an RJ45 splitter; that way OBDII data can be accessed on CAN bus 1, and ShiftX2 can be controlled on CAN bus 2.
A splitter like this would do the job. The OBDII cable would plug into one of the ports, ShiftX2 in the other port, and the splitter's end would plug into RaceCapture/Track MK2.
https://www.amazon.com/gp/product/B07C5 ... UTF8&psc=1
Hope the description visualizes it enough; we'll get it written up when we have a chance to demo it.
petik
Post by petik »
brentp wrote:RaceCapture/Track MK2 with it's dual CAN bus can work with ShiftX2 using an RJ45 splitter; that way OBDII data can be accessed on CAN bus 1, and ShiftX2 can be controlled on CAN bus 2.
Yep, that makes perfect sense. Thanks!
