http://www.megasquirt.info/ms2/knock.htm
I wonder if megajolt can accept that GM knock unit? Forget about the firmware, if it can be connected to megajolt and input can be read, then firmware will eventually be made to use it.
AL
Knock sensing with current hardware?
There is a purposely unused
There is a purposely unused "aux" input on the V3 board, which ties into one of the processor pins. So it conceiveably should be possible with some extra firware code to integrate something like this.
Can the previous version of
Can the previous version of the board (V2?) be modified to have that aux input?
Aye aye chief. When I get
Aye aye chief. When I get to knock sensing I'll ask you more.
