Reply to topic Page 1 of 1
Help with steering pot setup
Post Help with steering pot setup
Hello, I have a steering pot that varies in resistance from .8 to 1.7 ohms.
Ground to ground
5v to ref voltage
Pickup to analogue input 1.
It always reads 5 volts. Do I need a pullup resistor? Or have I messed up somewhere?
A
Post
Putting aside the sensor for the moment, try this:
* Set your analog input channel to 'Raw' voltage
* write the config
* Go to the dashboard to monitor the value
* Connect the analog 1 wire to ground. Does it show 0v?
* Now connect analog 1 wire to 5v reference. Does it show close to 5v?
if so, then you're reading the data correctly from the port.
Try double checking the connections to the steering pot and verifying that you have the center wire connected to the analog input.
Let us know how it works out.
_________________
Post
Im having the same problem. It is a AIM rotary steering pot. hooked to analog input2
Race capture just reads 5 volts. I put a volt meter in between the analog input wire and ground and it reads 2.6 volts goes up when I turn one way down when I turn the other.
Then I discovered the Race capture was reading correctly only when the volt meter was connected in the circuit as soon as I take the volt meter out of the circuit the race capture goes back to reading 5 volts.
Whats going on here? grounds all check out fine.
Post
RaceCapture has very high input impedance, and if the analog connection is not connected, then it will 'float' and show a voltage.
Setting aside your sensor, try this:
Set your mapping type to "raw"
Connect your analog input (say, Analog1) to Ground. RaceCapture should show close to 0v.
Connect your analog input to the 5v reference. RaceCapture should show close to 5v.
If you connect a potentiometer (variable resistor), you can connect the center tap of the variable resistor to the analog input, and then the side taps to gnd and 5v, respectively. Then, you should see the input vary as you turn the knob.
Hope this helps; Let us know what you find out!
_________________
