how to read RPM from canbus?
Q&A For ShiftX2, RGB sequential shift light <a href="https://wiki.autosportlabs.com/ShiftX2">Installation and Operation Guide</a>
jhawley
Post by jhawley »
I have RC3 setup and working well with the AEM preset. I just setup the ShiftX2 and run the Disco script with success. With the Sequential shift light script, I am not getting RPM. What is the function to pull RPM from canbus? The RPM function samples in the code are for ODBII and direct. Thx.
With the 2.13.x beta firmware there is a way to get a channel by name.
There's an example on the wiki for this:
https://wiki.autosportlabs.com/RaceCapt ... r_name_.29
When we release 2.13.x in production we will be updating the example script with this, but you should be able to adapt it now if you're running the beta firmware.
Let us know how that works out!
