Series Landrover
rmaddock
Series Landrover
Post by rmaddock »
Hello there,
I'm very interested in trying this out on my LandRover and wondered if anybody out there has already done it?
Any pointers or advice?
We're talking a late series 3 2.25l (petrol, obviously).
It's a good, solid vehicle which is hobbled by the ridiculous device that is the distributor and I'd love this option to work well for me.
I'm in the U.K. ....... if that makes any difference.
Cheers!
Robert.
________________________________
http://otly.mysite.orange.co.uk/
bill shurvinton
Should work great. Wanted to
Post by bill shurvinton »
Should work great. Wanted to do a series for a while.
Actually since finding out that BMW 316 inlet manifolds fit had all sorts of ideas.
get in touch if you need any advice, as I am in UK as well
Bill
rmaddock
316 manifold?
Post by rmaddock »
316 manifold? Oooo. Would that, by any chance, be a convenient way of fuel injecting a LandRover lump?
I'm going to start looking for the bits for the MJLJ. Can't wait. I hate the feeling of getting the tuning spot on and then having it go out again a week later.
bill shurvinton
Yup
It is. Built an MS for someone in greece for this. If only the heads fitted as well. Very keen to see how a series takes to the conversion. If its anything like the xflows I've been doing you will amaze and astound everyone with the improvements.
Get in touch if you need any help sourcing parts. I keep or have access to all the bits and Brent has just sent me a nice xmas parcel of boards cases and processors.
Bill
rmaddock
Parts
Post by rmaddock »
Hi Bill,
I'm getting more keen on this idea by the minute. Even my wife hasn't said "no" yet.
How comprehensive a list of bits do you have - the connectors and things seem to cause a problem here? And how much would a set cost me if I got them from you?
With the timing ring, are there any factors to be considered in it's positioning such as proximity to other rotating parts? If I were to weld (glue,sew, blue-tac etc) one to the crank pulley would it need to be clear of the edge of the pulley? Am I making myself clear?
Probably not.
Robert.
PioneerX
Pully location
Post by PioneerX »
Robert,
Just to answer your timing ring question. I have mine bolted to the fron of the crank pully on my Vx engine. The pully is actually the same size as the toothed wheel. This means that the edge of the pully is at thesame level as the top of the teeth, however even with the edge of the pully so close to the teeth it works fine. so I would say unless you pully is bigger than you timing wheel you shouldnt have a problem.
Regards
Simon
rmaddock
Ta.
Post by rmaddock »
Thanks for that Simon.
Merry Christmas.
Robert.
bill shurvinton
Go for it
I have all the parts including molex. If you want prices email me at bill at shurvinton.fsworld.co.uk
Also have a look at www.trigger-wheels.com for ideas on the type of wheels available.
Bill
