does the racecapture/track MK2 do Transmit CAN via LUA?
burn4005
Post by burn4005 »
I want to purchase a racecapture device to use as a GPS/IMU sensor to transmit GPS, accelerometer and Gyro data to my ECU via canbus.
I know the racecapture/pro has LUA scripting to create TX CAN frames, but can the new racecapture/track MK2 device do this?
it says in its specifications:
Scripting / Customization:
Real-time virtual (math) channels / custom channel mapping Via on-board Lua scripting
but i wanted to confirm this was true before purchasing one, and if any limitations existed.
Hi, RaceCapture/Track MK2 has the same Lua scripting capabilities as RaceCapture/Pro and RaceCapture/Apex.
Hope this helps!
