No VRef Power
Franco214
No VRef Power
Post by Franco214 »
So&#65279; I am currently having issues with my Throttle Positioning Sensor (TPS) not being recognised by the megajolt software. The issue is with the VRef pin on the megajolt there is no voltage showing on it (should be 5V). I've checked the wire from Megajolt pin to TPS is working (showing resistance on multimeter) however&#65279; there is no voltage showing either when the ignition is turned on or when the car is running.
Any ideas?&#65279;
Is there another pin on the megajolt that is 5V?&#65279;
No comment is a stupid comment so just post thoughts&#65279;&#65279;&#65279;
