VR Sensor and missing tooth position
damunk
Post by damunk »
I have two questions;
1) There are two pins on the VR Sensor. Ground and signal.
I have just noticed I had mine wired the wrong way around.
2) On my old build I was a tooth out (10 degrees) but car was tuned on rolling road without a degree offset.
How did the car run?
Unsure how your car was running if you had the VR sensor connected backwards!
For reference, the guide for the trigger wheel alignment is here:
https://wiki.autosportlabs.com/MJLJ_V4_ ... tion_guide
