Reply to topic Page 1 of 1
Perfect Tuning Universal Gauge and RaceCapture Track
Post Perfect Tuning Universal Gauge and RaceCapture Track
Going to install a Universal Gauge from Perfect Tuning soon (https://perfecttuning.net/en/), which has 3 analog (0-5V) sensor inputs and is also CAN bus enabled so wanted to see if anyone has connected this universal gauge with a RaceCapture device already and can provide guidance on how to set up the CAN mapping. I'd like the Perfect Tuning gauge to access and display sensor data from RaceCapture Track (and the MegaSquirt MS3 ECU, to which RaceCapture already has access to via CAN bus) and have the RaceCapture Track system access and log the sensor info from the Perfect Tuning gauge.
Thanks much in advance for any input/advice.
Happy Holidays.
CM
Post
Looking at the manual for that gauge, it looks like it can only receive data over the CAN bus (and then only from pre-configured ECUs), so since it does not transmit any of it's locally connected sensors, you will not be able to log that with the RaceCapture.
The other bad news, is since the incoming CAN isn't currently user configurable, you won't be able to receive any of the RaceCapture channels -- but you should be able to get the same MS3 channels that the RaceCapture receives.
Post
Thanks for the reply and assessment.
According to the founder/developer of Perfect Tuning the gauge is broadcasting the data of the attached sensors on the CAN bus. So, if thats the case (Ill double check), would RaceCapture be able to see and log it?
I believe (from what Perfect Tuning told me) that the gauge sends specific CAN requests for the preconfigured list of sensor/system data coming from the ECU, but supposedly its also possible to listen to CAN broadcasts - Ill verify with the developer if that could include the RaceCapture. Is the RaceCapture Track capable of doing a CAN broadcast of all data from attached sensors?
Thx
CM
Post
RaceCapture does not have a specific "CAN input format" or protocol - we can adapt to essentially any CAN data stream output by ECUs, sensors and so on - so long as we know the protocol (e.g. it is documented).
We have a very good guide here on how to do that mapping, using our UI tools:
If the perfect tuning gauge broadcasts CAN data with it's own protocol, and it is documented, then you can use our tools to map that data.
With RaceCapture/Pro, RaceCapture/Apex and RaceCapture/Track MK2, you can write a Lua script to broadcast channels over CAN bus. Some example scripts here:
https://wiki.autosportlabs.com/RaceCapturePro_Lua_Scripting_Examples#CAN_bus_scripts
Hope this helps!
_________________
Post
Thanks for the information and insights, Brent. We'll look into it to see how we can connect the two devices via CAN bus.
