programmable outputs +rev limiter etc
Josh_b
Post by Josh_b »
should i run my rev counter from the edis module or my MJLJ? is it just a 12v square wave?
also what does the high and low mode mean in the software? has anyone got a rev limiting if so how?
cheers
Looks like I answered your co
Looks like I answered your comment in the other post regarding reversed voltages. The HIGH/LOW setting means the output is turned ON if the value is exceeded (say 3000 RPM) if the output is set to HIGH, and turned OFF if the value is exceeded if the the output is set to LOW.
As for the rev counter, it depends how it's designed. You can try hooking the tach output to it and see if that works. Some tachometers require the high voltage kickback pulse coming from the ignition coil- There's a circuit for adapting to that as well that I will post.
