Canbus using 2 AnalogX's
Seasons over so im looking to clean up/simplify my wiring. I am looking to switch every sensor over to a canbus style harness. 8 linear sensors and two canbus AFR controllers. by using two AX's (one each end) and the AFR's/MK2 in the middle. would this work properly as far as canbus termination. see attachment for a sketch. thanks Dave.
- CANBUS.pdf
- (203.74 KiB) Downloaded 928 times
It seems like all the ASL devices have a the CAN bus terminated, and you cut a trace (or disable in software) the termination resistor. I was just responding that you should have termination at your two "end" devices, and none on any of the device in between. The lengths of your "branches" on the CAN bus should be 18" or less per the CAN bus spec, and the CAN Hi & CAN Lo Signals should be twisted together, about 1 twist per inch. Many CAN bus implementations don't meet all those specs and they work. But you can be sure things will work if you follow the spec.
