Bluetooth - Error Initializing
Platinum997
Post by Platinum997 »
Racecapture Track MK2
Firmware=2.17.4
Wifi works fine but bluetooth does not work. Under System Staus /Bluetooth, Status =Error Initializing
Have tried downgrading/upgrading firmware, disabling wifi module, CAN Bus, CAN Mapping and OBDII, same results.
let me know what else to try.
[/quote]
Thanks for the note. Please check that you have the correct firmware flashed - it should say RaceCapture/Track MK2 in the upper right when connecting. We only recently added guards in the app to prevent accidental flashing of incorrect firmware, so it is worth checking.
If it does report RaceCapture/Track MK2, then please contact [email protected] for support and we will get it repaired for you.
Thank you,
