help..with 97 ford ranger
lloyd_huey
hi...I can't find the edis on the drivers side fender..which leads me to believe that spark is controlled by the ecu???doe's anyone know where it is???...also can I use the tach signal from my tach in the dash to fire the megasquirt??? thanks lloyd
I think you would need better
I think you would need better to check on Megasquirt yahoo forum, this forum is about a diy ignition system using some off Ford EDIS parts combined with the diy controller.
lloyd_huey
ignition
Its been awhile since I've checked in...thanks for your reply...I can't get no answers to my questions at m/s forum...anyways, I hooked up a analog tech to the output to the dash tech and it worked..I still don't know if the signal will be strong enough to fire the m/s...I've looked at the wiring diagram and the spark control is in the ecu...thanks lloyd
