I have tried, to the best of my knowledge, everything to make race capture communicate with my S300. I have been unsuccessful.
Need help. I can see the S300 in my laptop; I can see race capture communicating , standalone, with the tablet.
However, we can not make race capture communicate with Hondata.
Pretty sure is a set up problem but need more knowledge and help as well but in a step by step form.
Need step by step instructions
herbertgomez
Do you have any kind of Telemetry system that can work with Hondata S300?
Canyonfive
Re: Need step by step instructions
Sure.
1) Do you have the canbus hooked up from the RCP to the s300?
2) https://www.hondata.com/help/smanager/i ... output.htm
As seen here the s300 does not have a termination resistor. You'll need one of those if you want it to communicate.
3) Post your RCP file so we can see what you did and help you.
herbertgomez
Thanks.
Yes, S300 Can H is hooked to RCP CanH1 and S300 CanL is hooked up to RCP Can L1.
Between both Can cables, we put a 120ohms resistor
How do I get/retreive the RCP file?
You can call me if you want- 305-336-6881
Also, RCP has instructions for RPM for our Bseries engines ECU that says to go via Pulse.
Canyonfive
Go to settings in your app > Then save > Go to the file explorer in your device and search for the name. > Email it to yourself, then you can post it here.
herbertgomez
Is this step is to install race capture in the tablet?
If so, its already installed .
Canyonfive
no its so me or anyone else can load your settings rather than have you post them. Its easier... Or you can post all your canbus settings and details.
The step-by-step instructions for Hondata is here:
https://wiki.autosportlabs.com/Hondata_KPro4
the general setup instructions are on the wiki http://wiki.autosportlabs.com.
