New Podium Connect - Firmware update failed
nickshanny
Post by nickshanny »
Hi there,
This is my third podium connect. I was trying to install the latest firmware and now the podium connect is stuck with a blinking SD Card Light. It was powered correctly and the update was progressing fine, but then failed while transfering the firmware. I am hoping that it is stuck in bootloader mode. Any ideas?
Nick Shanny
Re: New Podium Connect - Firmware update failed
Sounds like a failed firmware update. Simply perform the firmware update again; you will need to load a previously saved racecapture configuration in the setup view, then you will be able to access the firmware update page.
