RaceCapture integrated into Tunerstudio or vice versa
MX-5RACER
Post by MX-5RACER »
Since a lot of people seem to be running a Megasquirt (Man not be enough demand for this), is there a way to get RaceCapture as the source for TunerStudio instead of the Megasquirt? Reason I ask, if you were using a Pi Dash to run RaceCapture and as a dash interface for your data logging and Megasquirt data viewer, it would be nice to have some of the TunerStudio abilities to make changes to the tune on the Megasquirt.
Potential method: the RaceCapture device is used as a passthru device passing the Megasquirt data as well as the RaceCapture data (GPS, Yaw, pitch, etc.) into TunerStudio and have a Dashboard layout in TunerStudio to display the RaceCapture data. This would allow a user to use the Pi Dash to make changes to the tune on the Megasquirt and start/stop and view lap timing and/or data.
Douglas Q.
1999 Miata (VVT swap)
1990 Miata Track Car (Track Rat, with a VVT swap)
2013 BRZ (STX)
Re: RaceCapture integrated into Tunerstudio or vice versa
Sorry, no plans for that. You might want to check out the RaceCapture V2 beta app (see our Discord server) as much more powerful configurable dashboard application vs the current version; you can edit and share dashboard designs on the cloud and share them to your in-car dashboard. Some demo videos here: https://www.youtube.com/watch?v=mHCa-4ab-F4
Cheers,
