Hi.
I'm running an mk2 with almost no issues but hardcut limiter.
I guess that the info on the wiki page is outdated as long as my board (see attached) is different to any other on there.
Now my question.
How do I wire the MJ IOT make the hardcut limiter work?
Would it be to power coil + only from the MJ pin 16? I already tried and it doesn't work.
Thanks in advance
Hard cut wiring mk2
Hard cut wiring mk2
- 20210701-131134.jpg (179.72 KiB) Viewed 4232 times
- Mjlj_v4_pinout.png (12.38 KiB) Viewed 4234 times
Re: Hard cut wiring mk2
When hard rev limiter is enabled, you'd power the coil pack via the red connection in the upper left of the diagram, instead of via 12v. This allows the hard rev limiter to reduce power to the coils when the hard rev limiter is active.
