NO SPARK ADVANCE
o07wray
NO SPARK ADVANCE
Post by o07wray »
My Megajolt Jr has stopped sending spark advance.. my timing light shows only 10deg.. and its fixed.. my downloaded program map shows cells with 20+deg and it stays at 10deg.. The vacuum port (MAP sensor) is correct and it shows on the MJ jr's gauge and its variable with motor rpm.. My PIP & SAW connections are correct too.. BUT I STILL HAVE NO ADVANCE..
And on another note: When bench testing with my 9v batt, I would get " timeout cylinder count" and I cant do anything,,, the port is connected..but when I plug it into my EDIS on the running vehicle it logs in fine with no errors reported at the bottom of the window..
Chevy 1996 S10 2.2l 4cly
converted to carb, balancer mounted 36-1 reluctor, newly rebulit motor, Had MJ jr for 10 yrs working fine till now.
Re: NO SPARK ADVANCE
Sounds like it could be a hardware error. If you haven't emailed us already, email [email protected]
