I'm running a 2L Pinto in my MK Indy (7 clone) and am completely happy with the way my mechancal dissy is set up - but have decided to go with bike carbs
Got my V2.xx Megajolt a week ago from a chap on Locostbuilders forum - so spent the week playing with a laptop - and getting it talking - Got the latest firmware and getting familiar with the tuning software
Thursday morning I managed to raid a Ford Sierra with a CVH engine - moments before it went into the crushing machine
Got the EDIS4, full engine loom,coil pack with brand new leads!,throttle pot.vr sensor and front pulley with timing ring.....for FREE!!
Thursday afternoon I went along to a local machine shop to get a center spigot for the trigger wheel turned up on their lathe - they did it within the hour and bolted it on to the crank pulley (they were curious and wanted to look at the car- so I thought I'd make sure it fitted there and then !!
Got home and made a bracket for the VR sensor - and hooked everything up outside the car - to make sure everything was fine and no RPM shown on the software
Came back on here - looked carefully at circuit and schematic - noticed the posts regarding the TO92 transistors being soldered in incorrectly being a possible cause - checked the spec of PN2222a - sure enough - re soldered the trannies the right way - time for bed...
Friday - after work I hooked everything back up outside the car - YIPEE!!! all working fine - I even took the distributer off and hooked up the HT leads - and had it do the loudest backfire I have ever heard - it got all the neighbours out to see who had been shot!! and my missus came running out expecting to collect my life insurance!!
I duly turned the missing tooth to the right position and re nipped the trigger wheel down and it started first time - ticking over with a steady purr!!
Saturday - seperated the loom into the wires I need - and chopped out the ones I didn't - bolted the coil pack down - bolted the EDIS4 in and got busy soldering the molex connectors on- ceremoniously I unclipped the distributer cap for the last time and fired it up and went round the block - all be it with it stumbling and coughing most of the way (need to get a more suitable map?)
I made a bracket and hooked up the throttle pot to the end of the accelerator rod on the DGAV carb using a piece of copper wire - and used the calculator on www.cate1.co.uk/megajolt/ to get the TPS values - tried a different map (Brents basic map) and it runs better - but needs refining as we had a few coughs along the way - but I think I will leave that for tomorrow!!!
I'm seriously impressed with the unit so far - and the software and would like to thank all involved here and behind the scenes - as it has enabled me to get this thing up and running much sooner than I had expected
Looking forward to getting the bike carbs on there now and take it to a rolling road to get help refining the map
Is there any way of easily mapping my old mech/vac dissy to use as a base map till I can get the bike carb manifold sorted ? eg can I use the software to show me advance against RPM whilst actually running off the old mech/vac dissy - and putting them into a map? - or is there some other software I could easily use to do this?
Will the car need to be moving (EG UNDER LOAD) or will it work being just being in neutral?
Regards
Rob
________
Yasuhiro Wada (Honda) history
