To enable bench testing, I have written some PC software to simulate the VRS signal from a 36-1 trigger wheel. This was the easiest way for me to test my full MJLJ and EDIS setup - I have posted it on the web in case it is of use to anyone else. You can download the software and get a full description at:
<A HREF="http://www.heggs.co.uk/vrssim">http://w ... /vrssim</A>
EDIS Bench Test
Top work. i will give it a
Top work. i will give it a go...
Steve
Steve
- Contact:
Well done. Are you going to
Well done. Are you going to upload it here?
Uploading File
<A HREF="http://www.picasso.org/mjlj/?q=node/898 ... ode/898</A>
I've added it to the contributed files as a link - I want to keep the latest version on my website so I don't have to upload to different places when I make changes. Also it's only really of use if you read the web page anyway.
My original post of the link did not appear, and there was no option to edit this, so I had to add the link again as a comment. Looks like I am not the only person to have this problem - MrSandman seems to have had difficulty posting his pinto map file. Is there a problem with the file upload form, or does it not work for links?
