Zetec Map
John P
Zetec Map
Post by John P »
I could do with a proven map for a Zetec 2.0 litre running on bike carbs (actually Fireblade) with TPS rather than MAP.
I did see an earlier post from "fatbaldbloke" which seemed to indicate he had such a map but I'm not sure how to find it or if it's downloadable.
Any help would be much appreciated.
John.
4600cc
Search uploaded files
Post by 4600cc »
Search uploaded files section by clicking 5 Most Recent files link on the right side. Then go through each page by clicking next page at the bottom.
fatbaldbloke
Zetec map
Post by fatbaldbloke »
I copied my map from here. Still working fine, no plans to change it. You'll need to create the load bins first using the run time display to see what tps value is associated with full and idle throttle and the bit of code at the top of this page, then set up the zetec map near the bottom. Mine's a standard 2 litre so I used the 1.8/2.0 standard map.
FBB
http://www.cate1.co.uk/megajolt/mapping.php
