No 3D graphing when loading .cfg from previous version.
Pmoffatt
Post by Pmoffatt »
God knows why, but the entire graph just disappears off the face of the earth, works fine if I start a new config though.
I assume you're loading from
I assume you're loading from a file? What do you see in the 2d editing grid? are the values normal (0-49 degrees)?
Pmoffatt
Yep, all values appear good,
Post by Pmoffatt »
Yep, all values appear good, it may be because I'm using TPS rather than MAP?
Config file is here: http://www.box.net/public/lt8auk8h61
Pmoffatt
Ok, sorted it, it didn't
Post by Pmoffatt »
Ok, sorted it, it didn't like my preference for having the maps the other way up, doh.
New config, tweaked values, if of any use to anyone (vw aircooled on dellorto 40's, 1.8 litre from 1.6, fast road cam + heads, 4-1 exhaust): http://www.box.net/public/lt8auk8h61
And I spelt gauge wrong. ;)
Is there any way to change the graph perspective?
you mean you had the bins in
you mean you had the bins in reverse order? if that's the case then it won't be just the software not liking it; the controller will have problems as well.
so to confirm, rpm and load bins need to increase from load bin 0 to 9. the software should block you from doing this interactively, but invalid data may slip through on a file load. I guess not doing data validation on file load would be considered a bug.
Pmoffatt
Worked fine on the car ;)
Post by Pmoffatt »
