In my testing I haven't seen this yet. Have you been able to reproduce this consistently? Note it's possible that it was a problem in the controller as it cleared itself when you power cycled the unit.
Are you running your controller from battery? If so make sure the supply voltage is high enough.
If anyone else sees this it would be helpful to know.
Also - in case it was related to the file you're trying to load, can you send me the file you were loading?
You might want to consider a more descriptive title for your thread as well.
