'78 Triumph Spitfire
Just got this working. Excellent system. Easy to set up, install and manipulate. Had no idea I was leaving so much performance on the table with the stock distributor, especially with an engine that is a significant departure from stock. Here are the particulars on this engine in my '78 Triumph Spitfire 1500:
1514 cc displacement (0.020” overbore), 9.6:1 compression, balanced
“big valve” head (p/n 218139) w/ modified combustion chambers, ported and shaved
bronze valve guides, 3-angle valve grind
1.5:1 Harland Sharp roller rockers on Tuftrided rocker shaft, stock push rods
“B” grind cam (280° duration, 0.409” valve lift) and V.549 dual valve springs
dual-row TR-6 timing chain and cam gears
twin SU HS4 carburetors and 4-2-1 header exhaust
Here's a photo of the car (more photos to follow of the installation):
- 78_spit.JPG (186.77 KiB) Viewed 37659 times
I fabricated an interface mounting plate to allow mounting of the coil pack at the same location as the original coil using the original holes for the coil mount. The plate has 4 threaded holes to accept #10-24 machine screws for holding down the coil pack, and is attached to the car with two flat-head machine screws that go through the holes in the deck for the old coil mount, which also secure the bracket holding the heater control valve.
- coil pack interface plate
- coil_pack_plate.jpg (136.36 KiB) Viewed 37553 times
Starman,
Nice job on the installation. One thing I found after installing in my '77 spitfire, was that my tach was not correct so I made a LED tach and placed it in the ash tray (see photo). It runs off the six outputs. I like it there because I can flip the cover down when I don't want to see it.
- dash-tach.jpg (75.97 KiB) Viewed 37490 times
