Map for alfa boxer 1.7 16v
Hi, Having just fitted a megajolt to my '69 Beetle which is fiited with an Alfa boxer 1.7 16v engine,got it to run OK but just need a better map.Anybody got one or any ideas as to what I need?
A nice chap with some experience and/or a rolling road would be the most ideal solution. There aren't many alfa boxer engines on here i'm afraid.
The basic Map should be sufficent and safe to drive with the mean time.
alfa boxer
I'm working on a map for my alfa 33 1.7 8 valve, they're probably quite similar.
I found a graph of the ignition curve for the early Alfasud - probably 1300 (printed in 1975!). Although they state 8'@idle - 22'@2000rpm and 36'@4500 this graph looks really low - can anyone explain this? (I'll try and attach a scan)
- alfa workshop manual ignition.JPG (214.73 KiB) Viewed 52805 times
Martin & Walker Porsche 550 Spyder replica with Alfa 1.7 8valve boxer engine. MJLJ V4 / TPS
Ive now sorted the carb jetting out a bit as it was running lean at higher revs,I drilled the 135 mains out to 160 then 180 much better,she really pulls now,the CO's around 3-4 % when pulling hard in 3rd And the HC's are around 220 at idea which is great!
Alfa Boxer hows the map going? Mines not pinking but I know theys still more to gain on the ignition side as well.
- Heres the crank pulley
- pulley on engine.JPG (78.24 KiB) Viewed 52794 times
- TPS on carb spindle
- TPS on engine.JPG (75.21 KiB) Viewed 52794 times
- Alfa engine.JPG (77.18 KiB) Viewed 52794 times
alfa boxer
alfa boxer
jets
I am using .45 idle jets 140mains and 200 air correcters with 32 mm chokes
alfa boxer
jets
I have a device that tells u exactly what the mixture is at whatever load and revs your doing on the open road and you can ajust the map to suit. car runs really really well
although i need to build the aux input ,for cold starts this adds 3deg to the first three bins untill up to a presett temp.
alfa boxer
afr
I use a LM1 and wideband sensor
http://www.innovatemotorsports.com/products/lm1.php
Being into my DIY stuf i got myself a NAW OEM from http://14point7.com/ but i haven't got myself a sensor yet so its not plumbed in. Will do oneday.
