My engine doesn't appear to have a vacuum system - the distributor is mechanically advanced. However, the brake servo has a vacuum feed - can I tap off this to go to my MAP sensor?
Failing that, there is a manifold that connects the air filter assembly to the two carburettors (which, being Zenith models, apparently don't have a vacuum feed) - can I just drill a fitting into that?
On a vehicle-specific forum, someone who is installing full EFI wrote:
"The pinz engine has INSANE manifold pressure at higher RPM on deceleration and at idle... 24-27MP" - is this a problem for the MJLJ?
Vacuum/MAP feed?
Funky Diver
Here's a dreadful vignette-style (thanks, iPhone "flash") picture of the brake servo fitting (it's the braided hose going to the banjo fitting in the bottom left of the picture):
Any thoughts on how to add a fitting onto this. It's an M16 hollow screw? There's a 12mm pipe linking the two inlet manifolds (4-cylinder engine with 2 carbs) - I presume to balance things.
Something like this. This is the CIS injection model. The carb models have a similar one on the right hand side of the manifold. This T piece is also a valve to store vacuum escaping from the Vacuum reservoir of the brake servo when in low vacuum MAP (possibly engine stall) and requiring to still brake.
You may find similar ones on most models of VW's (petrol).
- VW map tap (330 x 219).jpg (21.82 KiB) Viewed 13493 times
